1 - 6 of 6 Posts
I need to troubleshoot some "kennedy -mcmaster" zero speeds....
I haven't found much information on Google, so perhaps they changed names? Don't exist anymore?
There are 4 wires...hot, neutral, and 2 signal wires that go back to the PLC?
I believe i need to start the conveyor and look for pulses on the signal wires with my multimeter...any advice for troubleshooting these devices? Thanks
If what you have are true zero speed switches, they will be directly coupled to the shaft (typically the tail pulley shaft on belt conveyors) and will have a steady state signal once the shaft reaches a pre-determined speed. In my limited experience, this is kind of the old fashioned way to do things. Every modern setup I've seen ueses inductive prox switches to send a pulsed input as the pulley rotates. This is done either by directly sensing differences in the face of the tail pulley or sensing rotation via an adaptor like a whirligighttp://www.go4b.com/usa/products/speed-switches/whirligig.asp.
Discussion Starter #6
This is what I have, http://www.plccenter.com/en-US/Buy/KENNEDY-MCMASTER INC/M801
I guess its just a 4 wire proximity sensor. But, it looks like its obsolete. So, I think I will just try and talk them into replacing them.
Although, I would like to be sure they are bad...because if I do install new ones and the NEW ones dont work ill feel like an ASS!
1 - 6 of 6 Posts
