In this article it states that receptacles that provide power for water pump mtors or for other loads directly related to the circulation and sanitation system shall be located at least ten feet from the inside walls of the pool.
so I would assume that hardwiring a motor from a panel that is 12 ft from pool is not an issue?
thanks for your help,
Murphy
Murphy
