Halo Old Work Cans
1 reading
11K views 45 replies 15 participants last post by  surf
#1 ·
I just put in 2 Halo remodel cans. They were 5" airtight cans. I can't get the clips to lock in on either can. I started late and didn't get finished so I'm going back in the morning. The clips have a sponge/rubber tape on them. I'm guessing that has to do with them being airtight. Does that tape need to come off for them to lock in? If not, what am I doing wrong?
#8 ·
The sponge has nothing to do with getting the clip down all the way... Simply to
Make the can air tight.
If the clip is difficult on standard thickness ceiling, the hole for the can is too tight. The lower portion of the clip that travels inside the thin vertical slot needs a bit of room to rotate. Either enlarge the hole just a hair, or with one hand, try to push the can in the opposite direction of the difficult clip, then try it.
Jamming it in with a screw driver is never a good idea. It can easily damage the housing itself or the impact can jack up the drywall. Just the last little bit on the clip is all you wanna use the screwdriver for.
#12 ·
Hopefully someone will invent a clip that you can tighten with a screw gun..:thumbsup:
Contrast lighting makes some great remodel cans that go in with a Phillips. Best remodel cans ever! I put in 11 today in no time with zero cursing or trying to jam the clips. Slide 'me up, use the drill to spin the screws tight and done. Less than a minute per can to put them up and they stay tight forever. I use them exclusively for 4".
http://www.contrastlighting.com/en/pdf/CA2000.pdf
#17 ·
I use a screw driver and linemans to bang em in... Ive put in hundreds this way..In plaster and lath, plaster and wire mesh, sheet rock. as long as the hole you made is nice and snug you shouldnt have a problem. You can however run into problems if you make the hole to big.. When you bang on it to set the feet you will run the risk of pushing the whole can up through the hole.. Unfortunatly ive become somewhat of a pro with halo cut in cans..:(
#40 ·
I only know of one IC retrofit light, the Halo H99ICAT. It's fluorescent though. Comes in 13w and 18w versions. Not dimmable.
Re the Contrast lights, they are my absolute favourite by a huge margin. Nothing else I've worked on is as quick and easy to throw into a ceiling, with minimal frustration. They also come out easily if you need access to the JB or the ceiling cavity later on. You have to use a connector, yes, but in my opinion that's still better(and faster) than NM clips because you never have to fight the clamp and squeeze it with your needle nose to get it to hold your wires in. Once you have done a few of them you get a rhythm and the lights go up real fast. It is a bit annoying that there aren't push-in connectors already there but at least you get a nice solid connection forever.
What I generally do with a contrast housing is pop the knockout and stick the connector in, then strip NM and make splices before inserting through the connector. Wrap the fixture wires onto splices and twist marrette...finished. After using these, anything with spring clips looks like it dates back to somewhere around the bronze age. The transformers on their low voltage lights are very high quality too. Have not seen many burned out.
Sent from my iPhone using ET Forum
#41 ·
I do it the exact same way. Works perfectly and is nice and fast.
#44 ·
Alright, kinda new here, but just installed 20 of these on a job the other day. Had a hell of a time getting those damn clips to lock in. Turned out to be blown in insulation under the tab that locks onto the sheetrock. Guy in the attack brushed away the insulation and ta-da. They all locked in like a charm
