Sorry about the lame picture. This is a subpanel mounted directly adjacent to the main service panel in a home. Several branch circuits were moved to this sub panel by having the ungrounded conductors routed from the service panel to breakers in this subpanel. The neutrals for the moved branch circuits were left connected to the neutral bar in the service panel. Is this allowed? The picture is lame because I did not show the connections to the circuit breakers but each is active. And you can see only two neutrals on the neutral bar. There is a separate ground bar.
