I commonly check motor winding resistance to see if it seems okay.
One thing I don't have is something to tell me what that resistance should be. Ohm's law tells me that the 30HP motor I'm looking (575V 3ph, 27.7A) at should have a resistance of over 20 ohms, and I know that that is nowhere close to correct. I would expect from experience that this motor would be less than one ohm resistance.
I did my measurement and got 0.547,0.548, and 0.549ohms through each coil including the wiring to the motor (disconnected from the motor starter).
Normally I would just say that this is a perfectly fine measurement for this motor, due to the consistency, and it passed a megger check with flying colours. However, when I tried to run it it blew all three 40A fuses. The problem could be the contactor rather than the motor, and I'm checking that now, but does anyone have a chart of reasonable/expected values for motor winding resistance?
