Mounting gear to stucco wall
6K views 10 replies 8 participants last post by  cuba_pete
What SW, NoBot, and Splatz said. Whenever we need to mount to our EIFS sided buildings, we cut back and use strut mounted to a base plate then build out to a smooth finish. In looks like an inset and elimates the holes which could be leaking and not detected for a while. The baseplate is easier to access for sealant inspection and we don’t have to remove any mounted equipment. I can get some pix on Monday.
This was one of our cleaner installs. I’m glad I went to take the pix, those wires need some help. I didn’t install the coax, that was a contractor
