I posted a question about a material measurement problem I had some time back. Got some really knowledgeable responses and in the end solved our issue of material wrapped around a roller with the encoder riding on that very spot. Different material thickness gave different lengths.
I made changes and it's good to go.
But there are still accuracy improvements needed on our other lines that need to be pretty accurate. One of them came from one or more members of this forum and will be implemented. The change will be to have the encoder ride on idler rollers as suggested in the comments.
So, here is my current question.
Background
The setup I'm using on the machine that measures length and needs to be as accurate as possible uses a 2500 PPR optical encoder. With the "gear ratio" it comes out to around 4400 PPR per foot on the existing line. The encoder / counter setup has one counter that counts up to the pre set, 4400, or in the new machine 2500, no "gear ratio" and then gives an output via built in micro relay to the printer to print the foot count, resets and starts over. The counter is currently set as an up only counter so if the material goes in reverse, or has vibration the count still adds. It also runs a second counter to display the actual foot count for reference.
*** The new counters will be up/down counters to counter any slight reverse or vibrations.
My question is would I be better off with a lower PPR encoder, or am I ok with the 4400 PPR ( 2500 PPR on the new line I'm building)? Which would be more accurate, the 2500 PPR, or is 600 PPR ok. I need the best I can get.
I'm asking this because I've purchased encoder / counter combos, chinese, that use 600 PPR encoders. They're used on material cutting lines that don't need to be extremely accurate so I've only done basic calibration on them.
The lines I'm currently building and upgrading need to be as accurate as possible. They'll be measuring and printing foot counts, 0001, 0002, 0003, on material from a couple hundred feet to as much as 2K-5k foot runs so a small error is amplified on a 3k run. Our CEO / Manager who is a pretty smart guy, not your average CEO, insists that our competition's length counting is more accurate than ours. The main issue, possible slippage, with our existing counting will be fixed using idler rollers to eliminate that issue.
Thanks, in advance.
Background
Thanks, in advance.
