Rough IN speed
1 reading
14K views 53 replies 29 participants last post by  99cents
#1 ·
Just hoping some were open enough to share some secrets on what method they use to complete jobs faster. What circuits do you pull first, and who is doing what at what time. Any help is greatly appreciated.
#4 ·
Don't look for speed.. mistakes will happen and then it cost you time.. :no:
Look to be efficient instead... have all the material on the job without making multiple trips out to the truck..
#7 ·
Start by laying everything out. Then box everything. While you're boxing, use your brain to figure out your drilling. While you're drilling, lay out your circuits. Then you'll know where to land your homeruns.
Drop a roll of the appropriate NM at each HR location. Pull 6-10 HRs at a time. Then go back and finish each circuit..... Pull the NM first. Then stuff and staple. Last step.... Makeup.
#10 ·
1st off...you and helper slam an energy drink. Repeat as often as necessary during the day.
Box out. Use a hammer for receptacles and a "stick of knowledge" for the rest.
Drill out.
Hang panel.
Pull home runs, cable and phone lines. Pull several at once, pull from panel out.
Do low voltage (garage door wiring, doorbell )
Start pulling rooms. Pull staple pull staple. Make up all light boxes & smokes while doing this. Pull out whole house.
Go back and cut in rec and switches.
Nail plate and firecaulk.
Sweep. Do final walk through. Done.
I like to start each step from the furthest point of the house away and work my way to the garage. That way everything is one repetitious motion. The only thing I do differently is when I pull my HR's, I pull from the garage out. Always always check behind yourself for anything you missed, have your helper go behind you as well.
#17 · (Edited)
Ill add my revised version - this is how to rough in with a good helper.
You- Mark out all the rooms with sharpie
HIM - bring material in, start banging boxes.
You - drill drill drill, hang panel
Him - finish boxing, set up wire at panel
You - pull home runs for 120 circuits
HIM - pull all 240 circuits, pull cable & phone, pull low voltage wiring
You and him - start pulling rooms
You- start cutting in switches
HIM - cut in receptacles
You - nail plate & fire caulk. Be checking everything
HIM- nail plate & fire caulk. Sweep.
Both - walk rooms and check. Pack it up. Head out.
With a good helper and enough work, you guys can get very fast.
#12 ·
Besides everything mentioned, always have the entire job already worked out in your head. Don't slow down to think about circuitry or box fill or how many receptacles per circuit. That should already be determined before you drill your first hole or mount your first box. If you're skilled with residential and know the codes, this won't take much time at all.
#20 ·
OK Mac, I give...
So tell me, how many electrical contractors are there out on that island? I'm sure the local economy would support just one more. Who's this Anna miller.. She cute? :whistling2:
Funds are low. keep an eye on the horizon for me. It's gonna be a long trip. :boat:
#16 ·
I cut in cieling boxes once i pull the last wire to it, instead of waiting to do all the cutting in at once. I hate bringing a ladder to the same spot three times for one job.
using the NM sheath stripper speeds up the process of cutting in a hell of a lot.
put marrettes on with a drill.
if pulling through an area thats going to have a bunch more wires pulled through the same spot, i'll wait to staple until all the wires are in.
#21 ·
2 man crew:
I have lead man doing layout, helper will start boxing. When done laying out, lead man starts hanging panel,bath fans,etc..
By then the helper or sometime even lead will have it mostly drilled. This is usually done by 11am or so.. (Not ceiling boxes just lower stuff, plugs switches etc..) by then we like to have most of the second floor pulled out,lead man has looped everything out and helper has pulled all homeruns. My guys will usually have all the second floor and most of the first floor pulled by the end of the first day. Second day is wrapping up the hardwire, starting with hanging cans, fan boxes,smoke boxes etc. that will keep the helper busy on a ladder wiring up cans,smokes etc.while lead man finalizes the wiring.
When all hardwire is done, lead man starts "cutting in" and helper wraps his cans etc up. Helper starts pulling "big wire" (a/c,range,hwh,dryer etc..). The leadman then is usually done with cutin and starts winding it down to little issues like phone and cable,helping helper finish loose ends etc..
This is usually the gameplan for a 1700-2500 sf home and we usually have on roughed in in about 2-2 1/2 days.
NOTE: this does not include landing wires in panels,building srvc etc. this is what works in our geographical area and will not fly in others. Where I began this trade (about 1700 miles north of here) we did it differently :)))
#22 ·
I used to do the homes for the contractor we works for alone. I always drilled the house out completely first, then pulled very single wire ( stove, dryer, has bond, low voltage ). Then I would start boxing and Tieing in at the same time. Lay out all boxes. Then box and make up box. That way I'm minimizing the amount of times I stop at one location.
#33 ·
When I was an apprentice, one of my co-workers was just like you - and proud of it.
I had to work with a journeyman cause I'm dumb. We built commercial and industrial services, wired motors and controls, welders, fire alarms, ran rigid pipe, teck cable, tray, etc. I learned tricks of the trade from a variety of pros in many different situations.
Sure I did a couple houses but the lonely apprentice taught me most of that.
You need to get out of there.
#34 ·
I probably will one day, but for now im a fresh second year witha good boss, and a fair wage. IMO, resi is great experience as its the easiest minimal startup for your own company and after I perfect being as efficient as possible at this, then i'll deal with moving on.
for now, Im happy. I feed my wife and kids and see them everyday. my boss is flexible if i need time off to take care of them.
#36 ·
Simple answer, whatever works for you.
13 years of high end residential...Personally;
Mark it
Box it
Drill it
Pull it
Do the ceiling
Cut in
Nail plate
Poke the outs
Clean up
Drink beer
If your panel is in the basement( or exposed garage, cut it in on the finish while your apprentice plugs and switches. If it's in a finished wall, cut it in while your helper does the nail plating, cleaning up , etc.
Having an apprentice who's green sucks, but at least they can pull the low voltage while you do the rest. If they are decent at the rest, leave them alone on the second floor (it's easier, no kitchen, generally no crazy lighting layout to avoid up there) it builds their confidence and you don't have to go up and down the stairs all day, they do.
Do yourself a favor, surprise the helper by doing some of the **** jobs, crawlspaces, attics, etc. They tend to respect you a little more, and don't bitch about always getting stuck doing the worst of the worst.
Everyone has their own way of doing things, I just end up running circles around most of them.
#37 ·
No offense intended.. But once you have done a few homes, anybody can rope a house out with a good amount of muscle memory (so to speak). I have a few guys that know nothing about 3 ph wiring so when I get a job at a restaurant or condo, I try to get them in on it. It provides them with experience under my direction and gets them to understand the trade a little better than they normally would.
#38 ·
No offense intended, but once you have run some pipe, wired a 3 ph motor, troubleshot a PLC, wired up a VFD, programmed a conveyor system... I could go on and on. Some of us have done all these things and more. Some only one thing over and over. 3 ph wiring is simple to do. Running conduit is simple to do. Don't belittle parts of the trade you don't think are worthy.
