Status
Not open for further replies.
Time to Trade in Your Insulated Screwdrivers for the New MEGAPRO® 6-in-1 DEFENDER Driver
9.2K views 0 replies 1 participant last post by  ElectricianTalk.com
#1 ·
We get it. Convincing professional tradespeople to try a new tool brand is a tough ask. After all, tools have to be relied on every day and nobody wants to deal with any issues with a new tool when there’s work to be done and money on the line. But MEGAPRO’s Defender VDE product line is worth your consideration.
Highlighted by the VDE certified 6-in-1 Multi-bit Screwdriver, this line also includes 8” Diagonal Cutters, 8” Needle-Nose Pliers, 8.5” Combination Pliers, and 8.5” Insulated Wire Strippers to help fill out your toolbox with the ultimate in protection.
You don’t see a lot of multi-bit drivers with VDE certification…and for good reason. MEGAPRO® worked to make the Insulated 6-in-1 Multi-Bit Screwdriver the best it can be. As part of the VDE testing, the MEGAPRO® driver was tested up to 10,000V so it can be rated for 1000V with absolute confidence. By going above and beyond, earning the VDE certification was the reward for MEGAPRO®.
MEGAPRO® built a whole lot more into this 6-in-1 Multi-Bit Screwdriver than just VDE certification. For example, it comes with retractable on-board bit storage, ergonomic comfort grip, Palm-Saver Cap, torque rating of 200 inch-pounds, rotating locking collar, and a lifetime warranty. No other VDE-certified multi-bit drivers offers all of those features.
It’s worth drawing more attention to features like the the aforementioned Palm-Saver Cap, which not only protects your palm from friction injury, but it also helps reduce fatigue. Combine that with the comfort grip, and you have a tool that is comfortable to use all day.
With Phillips, Robertson (square), and flat tips, you’re covered for all types of screws in electrical environments. The bits are sturdy and fit snugly in the locking collar without a lot of play. In other words, you don’t hear the bits rattling around in the MEGAPRO® Defender 6-in-1 while you are using it.
The screwdriver itself is compact enough to fit in a front pants pocket. The handle is sturdy and the whole kit feels decently heavy in your hand, (which is usually a good sign for durability). Impressively, the bit storage compartment is tight and doesn’t come open accidentally, which is a very nice feature.
While fastening is an important part of an electrician's work, no insulated tool kit is complete without an additional supply of hand tools. That’s why the DEFENDER series includes 3 sets of pliers and wire strippers. All of these tools are also VDE certified up to 1000V, and each adds value to an electrician's day depending on what tasks they’re up against in the moment.
These hard steel hand tools all have an ergonomic grip for your ultimate comfort and can cut a wide range of hard and piano wire. With the MEGAPRO® DEFENDER tools in your bag, you know you have quality, safety, and functionality.
The bottom line is that the MEGAPRO® DEFENDER Series are tools you can rely on every time you go to work. Isn’t that worth switching for?
NOTE: This is sponsored content produced in partnership with MEGAPRO®
Status
You have insufficient privileges to reply here.
