Got called in to work to change a control transformer that broke. It was a 600 to 120 and the neutral was tied on to case ground which went back to panel ground.
Is this common? Wouldn't the proper way be to run another neutral back to the panel because sending current back on the ground seems wrong.
Can someone elaborate?
