This is a weird situation. I have a client that really needs a panel upgrade. Their fuse panel is very much deteriorated.
I booked the replacement but I know they will be getting an electric vehicle in the future and possibly a hot tub.
It will be much easier to upgrade the existing service conduit in the spring because the meter base is being blocked by a fence and really high/full cedar hedges which are going to be removed come spring.
Instead of installing a 100 amp panel and replacing it later, I'd like to install a 200 amp panel and feed with with e existing #3 wires.
The 1-1/4" conduit will be fed from the back of the tub but after upgrading the service the tub will be fed from the top so it will not have to be removed.
Is this acceptable if I label the breaker at 100 amps max?
