anyone remember the formula for bending a 90 degree bend using (2) 45 degree bends (to get around an obstacle in the corner of a wall)?
Take a look at this click it is loaded with good info..anyone remember the formula for bending a 90 degree bend using (2) 45 degree bends (to get around an obstacle in the corner of a wall)?
You did not need to tell us that,,,,,we figured that out from the first sentence.:whistling2:I've done quite a bit of conduit work, but it is worth noting that I have bent a compound 90 exactly ONE time. And it was part of the electrician contest I competed in a few months ago. I royally f**ked it up too![]()
And by the time you're done measuring and crunching numbers the guys that just mock it up with a piece of scrap whatever or a folding rule are all done and moving on.You are all wrong..........And there you are.
That is NOT craftsmanship !!!jbfan said:Make two bends and put a coupling in the middle!!
