I’m looking for suggestions on routing conduit out of R3 panel boards. I have posted a photo to aid in explaining what I need to accomplish. The 480 volt panel on the right of the photo will have six-3/4” runs and one-2” run. I figured that the small runs of ¾” would come out the sides of the panel below the buss using LR’s and LL’s. The 2” run is the problem. It needs to go left past the transformer and 208 volt panel on the left and will feed a boiler that will be positioned about 10 ft. to the left of the 208 volt panel. I was thinking to use a 2” or 2-1/2” LR and come out of the bottom of the panel. A gutter might have worked but to get enough bending space for 3/0 cables would be limited. The transformer sits about 13” off the wall so I have space to go behind it. Any suggestions would be greatly appreciated.
