I know this question will get some guys
one guy have a multimeter, and this meter is rating for 1000V, 200amps, this guy use this meter to test a fuse in a live switch gear(by the way, the fuse is blow in this case), the voltage of the load is 600V, the load is now 400amps
1. situation A: he set the meter at the voltage testing setting, and test both side of the fuse, will the multimeter blow?
2. situation B: he set the meter at the current testing setting, and test both side of the fuse, will the multimeter blow?
