Just curious as to what you guys do to label wires in a control cabinet. I have been using my label maker with the heat shrink labels and the labels get eaten up pretty fast. I wouldn't mind so much but half of the label roll gets wasted when using the heat shrink tubing (bother p-touch). I was looking into getting some of the clip on numbers to help speed things up. I haven't found a good source for ones that would work on a wide range of sizes and they get kind of pricey for labels. Most of the control wiring is 14ga or 12ga MTW and 20ga MTW for the low voltage.
I've heard there are some hacks (workarounds) available online for some of that malicious company's products to make it stop wasting the tape. That is 100% by design just like the printers which count the sheets and won't work after n number of sheets to force you to buy new toner even though the canister is still half full.
One by one I eliminate companies I'll never do business with again. Top of the list is Xerox. Don't ever buy any of their products.
Since you brought it up I think I'll try it on mine today.
If you post your model number maybe someone will find the process and post it for everyone.
