Milwaukee Angler
2.3K views 33 replies 15 participants last post by  drsparky
#1 ·
I had the opportunity to use the Milwaukee "Angler"powered fish tape this last week. It wasn't my first choice. I prefer a good steel fish tape in almost every case. I had never used a power fish tape before and wasn't interested. My foreman kept recommending that I use it, and it was the only thing in the gang box, so I grabbed it. He's an older guy with a lot of experience, so I thought what the heck. If he likes it, its probably okay. While walking to my work area, it got lustful catcalls from from every crew I walked passed. It seems new fancy tools in Milwaukee red are as attractive to tradesmen as college freshman girls are to senior frat boys. I get the feeling that HR will prevent guys from oggling tools next. Maybe Milwaukee tools are red from the embarrassment over being admired so vehemently?
Here's my experience. It is heavy at maybe twice the weight of a full sized steel fish tape. It is bulky and awkward. It is slow. It has a weak clutch. I can't feel what bends I'm pushing through. It's expensive. The battery will die sooner or later at a bad time.
The only advantages are not having a mess of unreeled fish tape laying on the floor and it's easier to reel in a long run.
I don't really mind reeling in a long run once in a while, so that's not much of an advantage unless you're a smaller weaker person. If you are demure, the heft and bulk of it make it more of a handicap.
The job I'm on has the strictest safety policies I've ever experienced or heard of, so maybe the real advantage is that it reels in more readily. I'm sure I'll have to cone and tape off the area where I'm letting my manual tape coil up on the floor.
I'm curious what you all think.
#2 ·
Hand it to Milwaukee I have never seen another tool brand on a roll separating tradesmen from their money quite like Milwaukee today, but I would not buy it. No, I don't need to try it to decide, I understand what it does.
I agree that the feedback you get pushing or pulling by hand is important. You often will feel a sudden increase in tension and you can tell something happened, like there's a kink that caught the lip of the pipe at the feed end. This gives you the chance to stop and fix it, where the machine will pull past it and might create a huge headache with a skinned wire in the pipe that occasionally faults to ground.
I don't think there are many situations it would be worth it to lose the sensitivity. The time and energy spent pushing and pulling on a fish tape doesn't add up to much over the course of a day. It's nothing like the time and energy say a good bandsaw saves. So it's not likely to move the needle on how fast you get done or how beat you are at the end of the day.
I have a pretty nice assortment of fish tapes, I think it's important to have some variety. I have a few different steel tapes, all Ideal brand. I like the big handle and use a full sized case with a tape about 75' long left on it most of the time. It's light, long enough for most runs, and quick and easy to use. I have some others that are plastic and fiberglass. Most I keep a spring leader on.
I also keep a homebrewed vacuum kit that I can use with any shop vac. It's really important to be able to vacuum in strings. Actually if Milwaukee wanted to help me out, make an M18 vacuum that goes on top of a standard 5-gallon bucket.
I am sure the fanboys would tell me I'm missing out because I'm not using it with the Milwaukee red lightning $29.99 made in China five gallon bucket.
#3 ·
But what if you found one at a yard sale/craigslist/pawnshop/North Jersey fell off the truck screaming deal for $25?
#13 ·
From your description it sounds like it has zero utility for me. I always reel up my tape as I pull. I’m a purist though so my fish tape is immaculate and only pulls in string.
#27 ·
I've used one pretty extensively on a large commercial job, and can safely say I don't recommend it. Big, bulky, jams up, also certainly not meant for pulling cable on it's own (has no "balls"). If you use it like a regular snake and only use the power function to roll up and roll out the snake, it could work well for you-- at least until it gets jammed and then you're f****d.
