So I'm working on a project for the house, im putting up some outside lights (Mercury Vapor lamp) to light up the yard a bit, my question is, can you run UF sunlight rated romex overhead? What is required? I've heard you need a messenger wire and that it should be grounded. So my plan is to start from the breaker panel with a 15 amp breaker, run some 14/2 regular romex to a new switch by the backdoor, and on the load side of the switch, ill run some 14/2 UF cable down the wall and outside and run it underground, then to the service entrance pole, i will run it up to a mercury vapor lamp at the top of the pole, then from there I will run some more 14/2 UF to another pole with another mercury vapor lamp and end the circuit there. Would this be code, ive rarely seen it done, and i just wanna know if I would need a messenger wire and if so, what kind of wire do I use and should it be grounded?
