Primer when gluing PVC conduit
79K views 60 replies 28 participants last post by  99cents
#1 ·
Is it necessary to use a primer on pipe and fitting before you glue? The guys I work with now just use cement when gluing (like carlon pvc cement).
I moved from Chicago and didn't see PVC out there, so I have no idea what common practice, or the "right" way, is. I've noticed pvc conduit with purple primer before, but it all stuck out as extreme hack jobs (aside from the purple drips).
What do you guys think...Just curious...
#5 ·
Always just glue at my company, never had any issues with pulls afterwards. Mostly basic runs, 3/4, 1", 2" and 4", they try to trench out runs with long sweeps instead of sharp bends. Glue, stick, repeat, the labour savings are pretty insane. Maybe primer is best practice but never seen a big issue with glue alone. Taking the time to primer seems like it would interrupt the flow of rapid piping, if you hustle with just glue and the trench already cut you can run 200' in like 3-4 minutes.
#10 ·
I have been there and when someone predigs the trench they want to fill it up as fast as possible behind you and I've seen the pipe come apart..not always but a few times. Don't you or your bosses estimate the proper way to install to the specs. I can save a lot of time installing emt if I only thread the locknuts a couple of turns...it'll probably work just fine.
#15 · (Edited)
PROCEDURE FOR SOLVENT WELDING JOINTS • Use solvent cement and primer prior to expiration date marked on container. • Above 32°F ambient temperature, joints may be as- sembled without the use of primer, provided adequate penetration and softening of the pipe/fitting surface can be achieved with solvent cement alone. Primer is used to penetrate and soften the surfaces so that they will fuse together under a wide variety of condi- tions. The penetration or softening can be checked by drag- ging the edge of a knife or sharp object over the coated sur- face. If a few thousandths of an inch of the primed surface can be scratched or scraped away, proper penetration has occurred. Varying weather conditions affect priming and cementing action and may require more time or repeated applications to either or both surfaces
So I guess it not a short cut to lose the primer.
#37 · (Edited)
I have glued more PVC than anyone on the planet and primer is an absolutely unimportant messy waste of time on conduit.
2 to 4 inch water mains, yeah. I'm going to use it to prep the slick surface of plumbing PVC.
Our local POCO requires it on their installations (they don't install conduit). Whoever writes their specs (as usual) has never spent a day in the field. They read on the internet (or on advertising from the primer manufacturer)that primer makes a better connection so they require it.
Operator error.
1) There are only a couple thousandths of an inch between a good and bad joint. Experience tells you what to do. If the joint grabs right now, it won't pull apart. If you can still twist it after a few seconds, you need to do something about it.
2) Make sure your couplings are not stressed upon backfill. If you have a coupling hanging over a big dip in a trench and you dump several hundred pounds of dirt on it from a loader, duh.
#38 ·
Always use primer here.....
Our estimating program figures primer and glue automatically, so it's in the bill of material for purchase.
Primer I s required in every spec I've ever read.
If I choose not use it, I could be forced to tear out the work and 're-do or if a failure occurs, I have no leg to stand.
#39 ·
Dont prime. However on a side note why is everyone around here in such a damn hurry with everything? Slow and steady wins the race. I try not to short cut, cheat, or constantly be in a rush. Thats how mistakes happen. Which are far more costly. Slow the hell down. Back to primer.. i dont do it cuz i was taught we didn't need to because its not plumbing. The only electrical pvc conduit ive seen with primer on it was done by hacks cuz they didn't know better
#40 ·
I don't use primer on PVC (unless its pipe to pool lights) i feel it's a waste of time.
But,
primer will only make a better connection. It kind of is the "right" thing to do
So by no means would i call them hacks for using primer. Just because it isn't your method doesn't mean its wrong.
