41 - 60 of 61 Posts
Always use primer here.....
Our estimating program figures primer and glue automatically, so it's in the bill of material for purchase.
Primer I s required in every spec I've ever read.
If I choose not use it, I could be forced to tear out the work and 're-do or if a failure occurs, I have no leg to stand.
Are you a plumber?
I could furnish a house with the spec books I have been through and I have never seen primer in the 1600 sections.
I don't use primer on PVC (unless its pipe to pool lights) i feel it's a waste of time.
But,
primer will only make a better connection. It kind of is the "right" thing to do
So by no means would i call them hacks for using primer. Just because it isn't your method doesn't mean its wrong.
Naw not saying they are hacks for using it. Im saying the only pvc ive seen w primer was done by hacks. But thats not what made them hacks. It was everything else about the install ;)
on a side note why is everyone around here in such a damn hurry with everything? Slow and steady wins the race.
Time = money. You can be fast without making mistakes.
Installing two products where one is just as effective is just wasting time and money. It's not any different than pretwisting wires or taping wirenuts.
Plus that **** stains the hell out of everything.
dielectricunion said:
When you can pull wire through a sanitary tee fitting, you have reached true master level status [emoji1]
That's easy, they even come not only directional, but have a built in assessable splice location.
RIVETER said:
If you think that is funny you should log on to the plumbers forum and see what they say about us.
I tried and was quickly called a pipe-fitter hacking troll. They gave me the ban boot.
Reopening a 2014 thread looking for a code reference?
Read the instructions on the cement for ABS, PVC, or CPVC it will tell you to use primer.
I don’t see anything wrong with asking a question on an open thread. He was obviously searching for an answer before posting.
Instructions vary according to manufacturer. Ipex tells us primer is not required. I might assume there’s a difference between solvent cement and plain old cement.
41 - 60 of 61 Posts
