What kind of wire do I need to run for residential cameras? Cat 5? Rg-59? ENT? System would be integrated with an intrusion alarm system but the system is not picked out yet.
kludge?I agree with Edrick on the analog cameras, they are "legacy" items today. However, you might consider adding coaxial-Siamese cable because you never know what sort of kludge system might get installed.
be mindful that PoE specification is 100m, if you run past that without a repeater of some sort and have failures, your support call to the camera manufacture will end there.
There are plenty of cheep PoE cameras out there, but the NVRs are pricey and the picture/lenses on the cheep ones are not good. + megapixal cameras eat hard drive space for lunch. There are still a lot of applications where a good analog camera is the correct choice. Also, if they want PTZ, you are going to want a power supply local to the camera.
Link to gig PoE specification please.PoE also runs over gigabit. So saying that because you're using PoE limits you to 100mbit is incorrect. Thus using cat5e would still not be recomended. What it comes down to is guys saying oh well the device doesn't even come close to using the limits of the cable!
Certified is not specified, cat6 isn't "certified" to do gigabit either, until you install it and certify it with a tester.Cat5e is not certified to do gigabit, there's a difference. Cat5e will do gigabit however it usually does not do it well. Cat5e was created to support gigabit however is more prone to issues and doesn't hold up to the distance well.
Never mind not even worth it, I'm going to go do something more exciting. You have yourself a good night let me know what Fox news has on later.Will category 6 supersede category 5e?
Yes, analyst predictions and independent polls indicate that 80 to 90 percent of all new installations will be cabled with category 6. The fact that category 6 link and channel requirements are backward compatible to category 5e makes it very easy for customers to choose category 6 and supersede category 5e in their networks. Applications that worked over category 5e will work over category 6. - See more at: http://www.broadbandutopia.com/caandcaco.html#sthash.cLd40Mjt.dpuf
Alright, enough of the bickering. The argument between you two is unnecessary and irrelevant, so knock it off.
