When using SER cable to feed a sub panel, do you have to use the 60 degree column to size it?
It seams they did. Harry's post appears to be from 2011 where they excluded the requirement to follow 334.80 (ampacity for romex) Here is what it looked like in 2008.I heard but I did not confirm this part are they plan to remove the restriction on SE cable ?? { both tempture and ampacity rating }
