Where are you buying the generator from? They should be able to tell you what to use.
Exercise caution on this. The larger the generator they sell you is the more money they will make on the sale. It might be wiser to get the electrical contractor that did prior work on your home with a good outcome to do the load calculation for you.
yes i know there is the least amount of energy per unit in NAT, size it for that and no more worries
When dealing with with an installation that would use Natural Gas as the fuel I would multiply the entire calculated load by 1.25. That way the generator's capacity when fueled with natural gas would match the load.
When we installed the new generator for my fire department I sized it for Natural Gas fuel and used a 500 pound capacity propane tank as the back up. That way we could be confident that either fuel would carry the load.
Then we got an ice storm and, because it was policy, we called for a refill of our propane tank as a hedge against any failure of the natural gas supply. Our supplier never returned our voice messages because the device that would call their pagers had been connected to the non emergency receptacle a foot away instead of to the emergency receptacle which was installed right next to it. The dispatcher had unplugged it from the receptacle with the RED outlet cover marked EMERGENCY POWER when she was cleaning and plugged it into the wrong receptacle when she was done. We had the fire station, which served the area the propane supplier is located in, send a unit to see if they could find anyone on the site. All of the drivers and the manager were out making deliveries to clients that were afraid that they would run out of propane for heat. That unit's crew left a large piece of cardboard on their office door asking that they call us. Instead they sent a tank delivery truck with another 500 pound propane tank, a technician to connect it in parallel to the first tank and a propane tanker to fill them both.
10 days later, when power was fully restored, I went over to their office and had a look at their arrangements. Since I was there as an emergency service customer's representative they were very cooperative. I went out and found a lockable metal in use cover for the receptacle and had a Micarta label made for it which said "Power failure communications equipment supply. DO NOT DISCONNECT. I changed the receptacle from duplex to single, painted the cover red, and applied the new label. Once I had plugged it back in and put the new cover on it I gave the manager the key to the padlock. The padlock I used has what is called a "Frangible Shackle." It could be broken with any hammer, if they had a true emergency themselves, without damaging anything else. I talked them into obtaining telephone forwarding service from the telephone service supplier that would send their voice messages directly to their paging carrier after 1/2 hour with no one acknowledging the message. During a subsequent ice storm, a tropical storm, and the aftermath of a Derecho those all worked very well.
The propane company later added, on there own initiative, stationary cellular service, for their office and the managers home, so that people could reach them if the phone lines actually went down. They also had their unused business band radio system recommissioned and renewed their radio license. That allowed them to use direct paging and 2 way radio as a backup. When our fire chief pointed this out to the local all news radio station they broadcast a nice story about them and the State's Office of Emergency Management got them a State award as a fully disaster ready business. 2 doses of free publicity suited them right down to the ground.
Motto: try to remember to say thank you. It never hurts and often helps.
Tom Horne
