Sub Panel Install (w/pics)
9.4K views 33 replies 20 participants last post by  kawaikfx400
#1 ·
I don't think I have posted any pics of panel installs I have done on here yet, so I thought I would throw a couple pictures up of a sub panel I installed a few weeks back. This is a 100A 30 circuit QO nippled to a 200A 40 circuit QO panel. This is in a 7000 sq ft complete remodel/rewire, and this panel had kitchen, basement, and outside lighting circuits in it, so no AFCIs needed. Here it is after I made up all the circuits that were just kind of hanging out above the plywood, and then the 2nd picture is further along. I leave the extra wire, as that is what is required by the boss man. I have the extra pieces of sheath on there to label the circuits, so the panel schedule can be done later, in case some circuits have to get moved around for balancing purposes.
Also wanted to throw this picture on here. I had to go to big Orange on a Sunday to get some extra stuff due to some homeowner changes on Saturday (I worked 20 days straight when I took a trip back to NH), and the packaging just cracked me up. You'd think they were selling SE cable or something. :laughing:
Then here is another photo of where I had to bring conduits out from the basement for an electric gate, and the homeowner didn't want to see the conduits or LBs. Making that whole was a bunch of fun with the Milwaukee rotary hammer.
#3 ·
There will be more appliances and the like going into that panel, so I figured it would be better to allow for some flexibility when the project gets turned over.
I learned the scrape sheath trick from opening up a panel that another electrician had done, and decided it far superior to the white tape and sharpie I had been using before.
#18 ·
That's because those circuits hadn't been energized yet. I always install breakers into a panel in the tripped position. I then verify that the devices/equipment is hooked up at the other end, and then energize it. Plus it's fun to slap the breaker against my hand, trip it, reset it, etc as I am walking from the truck to the panel. :whistling2:
#33 ·
Jlarson said:
Nothing special order about it.
You just take the panel out of the box and turn it over, there is no top or bottom on that panel.
Ssshhhhhhhh. That was supposed to be a secret! Screw running the feeders from the bottom of the panel to the top. Just flip the beeotch over!
