Sucking at running rigid conduit.
11K views 27 replies 22 participants last post by  The_Modifier
#1 ·
Today I'm really tired. I ran a wee bit of rigid conduit, and I'm exhausted. My arms are tired. Any tips for rigid?
I built a junction box yesterday. In commercial, we call a 4x4 shallow a junction box. In commercial, they're 24x24x12 and have to be built with panduit and rails for those splicing things on them.
They hired a guy today who walked in with a resume and was working the next day. That's probably a pretty good feeling!
Anyway, I don't think I'll ever leave industrial. It's insane how few journeymen there are. Where are all the journeymen?
This might be an Alberta-only thread.
#8 ·
I wish you wouldn't get so technical. I can't follow all of your big words.
#21 · (Edited)
Industrial even bigger. Just finished pulling 600's thru an 8 foot by 8 foot box (8'x8'x24"), there was 12- 4" conduits entering box and 12 conduits leaving box (2 rows of 6 each). Had to build wire racks inside box to support the wire, was an angle pull thru box.
#25 ·
I believe 4" gal is actually 110 lbs a stick....
Kaboler , are you an apprentice or a journeyman?
Anyways...... If you plan your run correctly you do not need to make stub 90s as is the common practice (the shorter the stub the easier to spin on) and you CAN install them in corners. You must install your 90s first. Get them in place on the rack and strap them down and then spin straight lengths on to them. The trick with threaded conduit is to spin straight lengths onto the bent lengths.
