I worked with "CLX" cable when I was in the oil patch, which I think is same-same with Teck-90?
Anyhow, I'm bidding a job to feed an outdoor above ground hot tub. The feed from the inside the house panel goes to an in-grade pvc box, but the trench from there to the HT disco goes over-down-and around some retaining walls. Seems to me a CLX/Teck 90 cable is perfect for this application.
Too many bends in the run so I'm wanting to run Teck 90.
I emailed the inspector to get his/her thoughts on this install but have not heard back from them yet.
Anyone else use this cable for US resi applications?
You can't see the retaining wall's but you can see the slope angle here. I'd rather not deal with pvc or ltfmc and pull boxes. (the SO cord seen is from a temp connection not installed by me ((#8 btw)) )
Any American folks here use this wiring method in resi job's?
I also asked the inspector what he thought about surface mounting a length of conduit to sleeve the CLX feeding the HT from the edge of patio to HT . I've not heard back on that either. We'd rather not have to demo the mortared flagstone
