Okay, here's a scenario I need to get some input on.
I've got a water pump station that draws out of the river with three 40 hp pumps. The station is really old and out of date and is going to be replaced in a few years, but for now, the City wants to get some stuff updated a bit.
The pump motors are all controlled with across-the-line starters. In order for the pumps to not all start up at the same time and create a surge up the water line, they had someone come in a long time ago and put Delay-on-energize relays in, so that there is an interval of 15 seconds or so between each pump coming on.
Now the problem is that when they shut the pumps off, they all shut off simultaneously, which creates another pressure blast up the line to the nearest surge tank. I recommended that they put in some soft starters at least, but they didn't want to go to the expense. They simply want to add a delay on de-energize feature so that the pumps shut off in a sequence, instead of all at once.
I suggested a PLC but they don't want to go through the trouble when the facility is going to be replaced in a few years. So now I'm stuck trying to figure out a way to do this with timing relays.
Is there a relay out there that can do a DOE and a DODE contact on the same relay for the same output? Would it work to get a DODE relay and just put it in series with the existing DOE relay? How can I ghetto rig this thing up? :thumbup: Oh yeah, the control circuits are straight 480 :blink: No control transformer (although I can add one if necessary).
