I didn’t pass my final today because of a closet light situation. New construction three bedroom two bath 3000 ft.², everything was good to go except this.
There are two small closets that are 36 inches wide. I put a LED under cabinet fixture in above the door, Switched from outside the door. Inspector told me that the light above the door, 410.16 (c) , says that the light above the door, which is an enclosed LED, needs 24 inches of clearance from the side walls. Because the shelving is assumed to be 12 inches deep, and the clearance from light to the edge of the shelf is supposed to be 12 inches. So, because of the closet only being 36 inches wide, that means there is actually no approve location for a light.
He told me my options were to either completely remove the switch leg, cutting the wire completely inside the switch box, or purchase a fixture that is identified for use in a closet near clothes.
He cited this from 420.16 (c):
(5) Surface-mounted fluorescent or LED luminaires shall be permitted to be installed within the closet storage space where identified for this use.
my question: does anyone know of such a light? Having trouble finding something that is specifically identified for this use. I wonder if maybe it doesn’t even exist?
