I have seen on the web that some people call a "non-contact tester" a widow maker. How about this scenario?
if you place your Digital Volt-Ohm Meter (DVOM) across the two 120V lines at your air conditioner contactor, and one of those 120V lines is disconnected "broken off" from the outside kill breaker, you would read zero volts.
This is because the voltage potential difference requires a complete circuit.
If one of the lines is open or disconnected, there is no path for the current to flow, resulting in no voltage reading between the two points.
Using a non-contact voltage tester (NCVT) would still indicate the presence of voltage on the live wire, even if one of the 120V lines is disconnected.
Non-contact testers detect the electric field around an energized wire. The Non-contact tester will "see" if it is live, without requiring a complete circuit.
This tool can help alert you to a potentially dangerous live wire, even if the circuit isn't complete, offering an additional layer of safety when working with electrical systems.
Please tell me your thoughts.
