Status
Not open for further replies.
41 - 60 of 88 Posts
Luke, if the device you want to connect to has a screw that requires the wire to be wrapped around, then no, you can't wrap a ferrule around a screw. If the device has clamping plate that accept a solid wire in a straight orientation, then by all means use a ferrule to make a stranded wire into a solid wire. That's what they are for.
If it has a clamping plate, why not just clamp onto the stranded wire?
Am I the only one here still wondering what a ferrule is and how it’s used on a device?
Hack, a ferrule is just a mini term like a fork, a ring, or a butt connector that gets crimped on the end of a stranded wire to make it like a solid wire. I haven't really ever used them as I think forks are easier and even then I only use those in peckerheads for the ground. On a receptacle I don't think anyone would ever use one.
They keep stray strands from happening. Particularly useful in terminal blocks or electronic equipment where the terminals are very close together and fine stranded wire is being used. Try one on a 22awg stranded going into a sensor terminal block and see if you don't grow to like them.
Though there's no reason one couldn't use them on any stranded wire where you don't need to wrap the wire around a screw. They even have doubles where you can crimp two wires together into one ferrule.
Just wanted to test my pic posting privileges now that I have enough posts.:wink:
Save
There is no rating. They are cheap Amazon crap.
Well then Luke, unless they are approved for use in your jurisdiction, you shouldn't use the Sopoby ones. There are many manufactures that have approved ferrules, some up to 600V.
They are not expensive either.
Save
41 - 60 of 88 Posts
Status
You have insufficient privileges to reply here.
